Action flow module/filter to remove the duplicate operations/output from array aggregator module.
  • Aug 19, 2024 12:17 PM UTC
  • 129 views
deepak.kumar30
Level 3
There is 9 similar operations/output from the Array aggregator module inside action flow. How to reduce or remove the duplicate operations from the array aggregator(considering that change is any prior modules not possible but ready to adapt any filters ot add any more modules after the array aggregator module giving 9 similar operations)? Thanks!AG
matt.witty13
Can you show what your array is grouping on? The module is coded to not have duplicates, as well as the data you're likely pulling in isn't duplicating.
Also, what do you mean by similar? Similar operations are still unique but closely the same, but not identical.
deepak.kumar30
Level 3
Hi Matt, All the above 9 operations are identical, not unique. Would you recommend to have very short call?
