Action Flow filter date
  • Dec 12, 2024 3:38 AM UTC
  • 317 views
junwei.chai
Level 4
I want to create an action flow by querying a data within a specific range of date (e.g. total number of PO created from 01 November 2024 to 01 December 2024).
How can I achieve that?
Forum|alt.badge.img+5
Hi Junwei,
When querying data from Celonis in an action flow, you can scroll down to the ‘Filter’ section of the module. Here you can select a predefined filter in the KM you are working with that filters the dates, or you can write a filter inside the module by changing ‘Filter Type’ to ‘Custom Filter’.
junwei.chai
Level 4
  • Level 4
  • Dec 13, 2024 1:07 AM UTC
Hi ​@andrew.cirin11,
Thanks for the replies. I have found filter section but am unsure which formula should use to filter out as I did not use KM before. Could you please guide me more about this? Thanks
Hi Junwei,
Apologies for the late response. You can create a formula for this action which can be something like this:
FILTER <table.datecolumn> BETWEEN {d '2024-11-01' } AND {d '2024-12-01' };
You can read more about the BETWEEN function here: https://docs.celonis.com/en/between.html
junwei.chai
Level 4
  • Level 4
  • Jan 9, 2025 1:19 AM UTC
Hi Andrew,
Ok understood. I have managed to solve this now
Thank you!
