Action flow CSV Formatting
  • Apr 14, 2026 12:14 PM UTC
  • 377 views
Nick.Monteleone
Level 5
I am having an issue with dates and exporting to csv. They are both kpis but any way I set it up its not coming over in any format. Need some help to get this working to show as MM/DD/YYYY.
Result of the action flow
 Result after action flow runs
KPI 1
KPI 2
denis.pede12
Level 7
Hi Nick, that’s actually a quick fix which you need to implement in the action flow itself.
  1. Open the “Create CSV” module.
  2. Go to your date column and use the formula “formatDate” for your column:
  3. In my example I used the format “YYYY-MM-DD hh:mm” to get the following output: “2026-04-15 14:52”. You simply need to use the format you expect.
  4. Test by running the module only and checking the output.
I hope this helps!
Cheers,
Denis
Nick.Monteleone
Level 5
Hi I will try this!
I ended up fixing it manually with updating the KPI to this formula vs the formatting on the KPI.
CONCAT(YEAR("INVOICE_PROCESSING"."INVOICE_DATE"), '-', MONTH("INVOICE_PROCESSING"."INVOICE_DATE"), '-', DAY("INVOICE_PROCESSING"."INVOICE_DATE"))
Forum|alt.badge.img+28
Hi ​@Nick.Monteleone,
Dates in Celonis are in Unix-Epoch format, being milliseconds after 01-01-1970 stored as an integer. This is exactly what you see in your Excel. Converting it to a String would solve it visually as you did and ​@Dennis suggested. If you want to maintain its numerical functions (i.e. doing calculations with it), you can keep it as integer and let Excel do the formatting (for example: https://exceljet.net/formulas/convert-unix-time-stamp-to-excel-date).
JP
