Action Flow - Create Excel module - how to rename headers
  • Mar 24, 2026 12:26 PM UTC
  • 209 views
Malgorzata Korus
Level 2
Dear Colleagues,
I have a simple Action Flow where I “Get Rows” (Celonis module), then I “Create Excel” (XLSX Excel files module) containing the data I selected, then I “Send an Email” (Email module) with the excel I had created.
Everything works, however in the “Create Excel” module where I do include headers, finally in the excel file they look like this: “O_CELONIS_PURCHASEORDER.PurchaseOrderItem” - is there any way to customize these headers or at least get rid of the first part “O_CELONIS_PURCHASEORDER”?
Thanks and kind regards,
Malgorzata
abhishek.chatu14
You need to recreate the Data Structure with the correct header name
Malgorzata Korus
Level 2
Hi Abhishek, many thanks for the tip. It works as expected. :)
