About KPI setting in transformation-center
  • Jun 17, 2022 7:00 AM UTC
  • 73 views
I'm trying to set a KPI in transformation-center, but it's been loading all the time and isn't reflected.
KPIs have a green mark. However, the numbers and graphs are not reflected on the screen.
(In the overview, the blue mark is spinning all the time)
Can you tell me why?
  • Level 0
  • Jun 19, 2022 11:29 PM UTC
Dear Manabe,
Thank you for reaching to us.
In order to be able to assist you further, we would suggest to send an email to servicedesk@celonis.com with detailed description.
We will gladly assist you.
Thank you in advance.
