A definition of "use case"?
  • Dec 19, 2022 9:13 AM UTC
  • 8 replies
  • 126 views
Anybody has a "strong" definition of what will be a use-case in Celonis?
I am thinking on a wording that could be use in proposal. Like when we limit the effort to "3 use cases", add that definition.
TIA
teuku.faruq13
Level 9
Hello @Guillermo Gost , are you trying to define scope of work? I think it is depend on how do you want to position and approach Celonis itself. My past experience was:
  • Use Case for specific tools function or area to be improve (eg. planning for tools function or on time delivery for use case)
  • I also use process / value stream when describing the scope
Hope that help and let me know your thought.
  • Dec 19, 2022 11:15 AM UTC
Well, trying to clarify... let's imagine I say in a scope of work:
  • one process
  • one system
  • 2-3 use cases
"process" and "system" are clear the meaning, and it is straightforward to define. But... "use case" ?
What's a "use case"? How to define it in a scope of work?
  • Dec 22, 2022 12:56 PM UTC
Hi, do you want specific use cases within a process like O2C or P2P ?
For example like, "how many deliveries are late?" or "do our VIP customers get the goodies we promise them?" --> here times on O2C
"How many price changes do we have in order type XY?" --> P2P
Or the shared service center question "how many invoices does a division post per employee?"
  • Dec 22, 2022 12:57 PM UTC
Nope, I am trying to find or imagine a "standar" definition. Something that could be applicable to any process, industry, etc...
andré.tafur
Level 8
Forum|alt.badge.img+19
Hi Guillermo,
Perhaps you could associate the term "use cases" with the "number of execution gaps" you can address within the scope?
I hope that doesn't sound far-fetched.
  • Dec 28, 2022 2:47 PM UTC
Hi Guillermo,
Hmmmm.... not a bad idea... at the end, a use-case is to resolve one or several execution gaps....
BTW after holidays I will try to ask some Celonis ppl I am working with.
  • Jan 3, 2023 4:12 PM UTC
Each use case, as I understand it, could be said to be equal to a seperate project, because each use case sets out to solve a separate problem statement or give visibility on a certain issue.
  • Jan 28, 2023 5:25 PM UTC
Hi Guillermo,
Besides the number of Execution Gaps, maybe also add the number of KPI's and Action Engine Skills or Action Flows. E.g a use case is at least:
  • An Analysis to identify 1 Execution Gap in the process
  • 1 KPI for the Execution Gap
  • 1 Action Engine/Action Flow to resolve the Execution Gap
