1. Celonis EMS connection with Power Bi and 2. User details
  • Dec 2, 2022 4:30 PM UTC
  • 6 replies
  • 161 views
Have 2 concerns:
1. Heard from Celosphere that now celonis EMS can connect with Power Bi.. Is it live? If yes then how??
2. Can I create a olap on how many of them are using a particular dashboard and user details???
abhishek.chatu14
Hi Sushmith,
The first part is a little tricky to answer you can get in touch with Celonis through support tickets.
The second part the answer is yes but there are some limitation for the same
  1. You must have more than 80 users
  2. You have to regularly update the analysis with a CSV file generated by Celonis
You can get started here
https://docs.celonis.com/en/user-adoption-views.html
https://docs.celonis.com/en/studio-tracking-service.html
matt.witty13
If you head to the Celonis marketplace, they have some Power BI options where you will likely need to request access.
  • Dec 4, 2022 6:53 AM UTC
I heard that the PowerBI adapter could also be a problem license-wise. Does anyone know more?
Forum|alt.badge.img+28
Hi @sushmith.decha,
On the Celonis Docs more details are provided:
EMS Connector for Power BI (celonis.com)
It seems that once you have the installation file via the Celonis Market Place, nothing is in your way to connect Power BI to Celonis.
If you want to extract data from Power BI to Celonis, there is a Action Flow connector for that: Microsoft Power BI (celonis.com)
  • Dec 5, 2022 11:31 AM UTC
Hi @sushmith.decha,
Hi Jan,
How are you?
So its not a connection from Celonis to PowerBi?
Hi Jan,
How are you?
You can do it in both directions. For extraction data from Celonis to PowerBI, see the first link I provided above:
Celonis_PowerBI
