Measure throughput time between PR received and PO sent to supplier for happy path and non-happy path over time (month)
  • May 21, 2021
  • 92 views
Hi there,
I would like to ask for you feedback to do the following: I would like to measure the median throughput time over time (per month) in two different column charts.
Happy Path column chart
The first chart should display the median throughput time from "PR received" to "PO sent to supplier" where "PR received" is directly followed by "PO sent to supplier" (Happy path). The result should be displayed in a column chart: January - 20h, February - 23h, March - 18h etc.
Non-happy path column chart
The second column chart should display the throughput time for all PR that didn't follow the happy path. This includes all PR request that did not go straight to "PO send to supplier", but had other activitites in between. The result should be displayed in a column chart: January - 40h, February - 46h, March - 36h etc.
I am currently managing to get to the numbers seperately, but not displayed over time (per month) in two different column charts in one dashboard.
Any help is highly appreciated!
Thanks!
  • May 27, 2021
Hi Marvin,
you could do with the following:
  • use document creation date per month as dimension: ROUND_MONTH (doc_creation_date)
  • use one of the following as KPI with Decimal Number as formatting.
Happy path:
MEDIAN(CASE
  WHEN MATCH_PROCESS_REGEX ( "_CEL_P2P_ACTIVITIES"."ACTIVITY_EN", ' Activity_A ' >> ' Activity_B ' ) = 1
  THEN CALC_THROUGHPUT (FIRST_OCCURRENCE[' Activity_A '] TO FIRST_OCCURRENCE[' Activity_B '], REMAP_TIMESTAMPS("_CEL_P2P_ACTIVITIES"."EVENTTIME", HOURS ) )
  ELSE NULL END)
Non Happy Path:
MEDIAN(CASE
  WHEN MATCH_PROCESS_REGEX ( "_CEL_P2P_ACTIVITIES"."ACTIVITY_EN", ' Activity_A ' >> . >> ' Activity_B ' ) = 1
  ELSE NULL END)
and if you put both KPIs in the same graph, you can even compare the figures.
regards
Marc
  • Level 1
  • May 27, 2021
Marc Rillaerts! Thank you very much!
You really helped me out and I learned a lot about how to use >> and >>.>> in PQL. This was the missing link!
I highly appreciate your input.
The numbers don't exactly match with the Throughput Time (Details) tab. Is there any reason for this? It's around 10-20% difference.
A second question would be why the Median calculation only returns whole numbers without decimals, although I selected Decimal format with ,.2f.
Thanks a lot for you help again!
Best regards
Marvin
  • May 27, 2021
Best regards
Marvin
Hi Marvin, the pleasure is all mine to have helped you out ;-). For the difference in figures, calc_throughput or a time difference statement ‘just’ calulates the time spent between the 2 given activities. This will then include both your happy and unhappy flow. The formula I used is first checking which flow to use to calculate the median time. And it uses ‘null’ for the cases that are not relevant. For the rounded result, I have no clue as such. It’s difficult without seeing the screen. Sorry for that. regards Marc Marc Rillaerts from my mobile.
