Kann man CO2 Werte anzeigen lassen. Ich möchte eine Excel Datei mit Aktivitäten und deren CO2 Werte hochladen, doch bislang habe ich keine Lösung dafür gefunden?
  • December 28, 2021
  • 252 views
Of course, you can upload the file (I prefer csv, but excel should also work), then make a foregin key between activity table and the CO2 table. Then, in the front-end you should be able to for example sum the CO2 for all activities, or make KPI based on that.
Do you have problem with some specific step?
Mateusz Dudek
  • Level 1
  • January 28, 2022
Hello Mateusz,
thank you for your´e answer.
I already solved the case.
best regards,
Nesli
