I have registered and trying to upload a CSV, i am not able to see the data . The window is so small with no scroller, I am not sure if this is a browser compatibility issue or I have access issue on the free platform. How to resolve it ?
  • December 19, 2023
  • 222 views
Hi, you can't see the hole data you are exporting. I recommend that if you want to check the data that you are exporting, create a view and in that view create a table with all the fields and enable export data. That way you can download an Excel and check if you are successful in the export. But in my experience, you can trust that it will work well.
