How to use free plan environment with own data from a file?
  • August 24, 2023
  • 301 views
Hello! I'm having trouble understanding how to use the training / free plan environment with my own data. There is a guided tour that uses demo data set, I went through the beginning of it but don't understand how to create a project with my own data... I have a CSV file with an event log example. This is what I have tried so far.
  1. Go to Studio, create a new package, first step is "Choose Data Model". There is no option to upload a file and only the demo models are available on the list.
  2. Go to Business Miner. It shows a message about "Setting up Project Workspace", click Let's Get Started. Select Process Type = Other. This takes me to a screen that has "Choose your Data Model" and it has an "oops" message (see screenshot) saying to "contact your admin". There is no "admin", I'm just by myself trying to learn things...
  3. Click on Data, then Data Integration. This shows some kind of diagram with an item "Connect to Data source". This finally has an option to upload a file and I'm able to upload a file successfully. The file is in the list with a green checkmark next to it. But what do I do next? There are no buttons and it seems to be going in circles and not actually "connecting" anything...
Note: I've also tried Celonis course on Udemy. In that course, the author uses something called Quickstart to upload a file. There is no such option anywhere. Am I missing something? Am I in a wrong place? Is what I'm trying to do no longer possible? I'm lost completely... Help?
Thank you.
1
Dear Jelena, Thank you for reaching out to us. Regarding the questions that you have, we would suggest you checking the following help article which shows steps to import from CSV and XLSX with Quickstarts https://docs.celonis.com/en/importing-from-csv-and-xlsx-with-quickstarts.html. Besides that, kindly note that there are courses in our Academy that you can check i.e: https://academy.celonis.com/courses/celonis-kickstarter Thank you for your understanding. Best regards, Valmira Abdiu
  • Level 1
  • September 11, 2023
Thank you for a reply! I understand the steps from Quickstarts, the issue is I'm not seeing Quickstarts anywhere in my environment. The document shows Quickstarts in the toolbar, right at the top. I don't have it. It also says "depending on how it's configured" but where is the respective configuration? I'm not seeing Quickstarts as an option to add to the toolbar and I'm not seeing it mentioned anywhere in the settings. Below is the screenshot of what I'm seeing.
It also says Quickstarts can be accessed in Studio but doesn't say how. I don't see anything even remotely resembling Quickstarts there. It just has "packages". Every video has Quickstarts prominent in their environment but my environment looks nothing like the videos. Sorry, I'm still lost on how to get to Quickstarts. :(
