Export of visualisations as images
  • October 20, 2020
  • 119 views
Hi, i was wondering if there is any way to export the path visualizations as images (or as videos for the animation). ANy help is appreciated! Cheers, Olaf
  • Level 4
  • October 23, 2020
Hello @olafbriese, By visualizations, Im presuming that you mean the process flows. Yes you can definitely do so. Please find the solution in the below link Exporting Workspace analysis to PDF or PPT format Analysis Hello @RaghuVikas.Polisetty, You can Export the analysis to either BPMN export or its PNG Component. For PPT, you can use the PNG component. However, you have to enable the Export option in the settings. Thank You. Warm Regards, Jayanta [Export] Warm Regards, Jayanta Borkakoti
  • Level 0
  • November 23, 2021
Hi Olaf,
you cant directly export them as an image. However I would suggest taking a screenshot of the process flow you want to capture. The Export function suggested above is only available in Celonis 4 and won't work in the EMS.
Kevin
