Dear Colleges,
  • June 17, 2021
  • 5 replies
  • 31 views
Dear Colleges,
I have lost access to the analysis that I made at the P2P.
Unbenannt
Forum|alt.badge.img+2
  • Level 1
  • June 21, 2021
AP is the same.
  • July 5, 2021
Hi Raphael,
I am not a SNAP specialist (did one for the fun long time ago), but you had to create a datamodel to define the activity and case table and further any data tables you want to use in your analysis. Check if it can be reloaded in Event Collection.
May be you will also need to reload the data itself?
regards
Marc
Hello Mark, this is already solved.
Luis Kentzler helped me a lot, I am really happy with his support. I have just one ticket open regarding a filter that I am trying to set in a Pivot Table that I created. If you can help, that would be nice.
Thanks a lot, Raphael Cornea
  • July 5, 2021
Hi Raphael,
ok, good to read. I didn't see that it was resolved.
If you could share the solution, it could help others in a similar situation.
For your other request, if you could add some more details to it, it would help understand the problem.
regards
Marc
  • Level 0
  • November 23, 2021
Hi Raphael,
are you trying to apply a component filter to the Pivot Table or where are you trying to filter?
Kevin
