Why there is a difference in throughout times calculated for a bucket created by using a PU_COUNT function and a bucket created by using a CALC_REWORK function?
  • Jul 29, 2021 8:49 AM UTC
  • 170 views
Hi!
I have a use case when a specific field within 1 case can be changed multiple times during the case lifecycle (e.g. fields containing metadata around the Vacancy case). The aim is to figure out what is the influence of specific field changes on the Vacancy throughput time. For this, I am using range buckets calculated based on the number of specific field changes per Vacancy.
I've created 2 tables with buckets: the first table allocates a Vacancy to a range bucket (OLAP table dimension) using PU_COUNT function and the second table does the same using CALC_REWORK function (all formulas are provided below). Then I calculated the # of vacancies in each bucket and the average # of field changes in a bucket (both tables show the same result). Then I am adding throughput time calculation to the tables, and the result is the same at a first glance. But when I hide the column with average # of field changes in a bucket from the second table, throughput time is recalculated. Please, see the attached gif.
CALC_REWORK Bucket vs PU_COUNT BucketCould you please help me to figure out why the throughput time calculation is different between the tables? The expectation is that both tables must calculate the same values, as there is no difference in the formula used for throughput calculation.
Formulas used:
Bucket with PU_COUNT:
CASE
WHEN PU_COUNT ("GTO_Vacancy_Current_State_csv", "GTO_Vacancy_Workflow_csv"."FIELD",
"GTO_Vacancy_Workflow_csv"."FIELD" IN (<%=With_field%>) AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') =0
THEN 'no changes'
"GTO_Vacancy_Workflow_csv"."FIELD" IN (<%=With_field%>) AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') = 1
THEN '1 change'
"GTO_Vacancy_Workflow_csv"."FIELD" IN (<%=With_field%>) AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') > 1
AND PU_COUNT ("GTO_Vacancy_Current_State_csv", "GTO_Vacancy_Workflow_csv"."FIELD",
"GTO_Vacancy_Workflow_csv"."FIELD" IN (<%=With_field%>) AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') <= 5
THEN '2 to 5 changes'
"GTO_Vacancy_Workflow_csv"."FIELD" IN (<%=With_field%>) AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') > 5
"GTO_Vacancy_Workflow_csv"."FIELD" IN (<%=With_field%>) AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') <= 10
THEN '6 to 10 changes'
"GTO_Vacancy_Workflow_csv"."FIELD" IN (<%=With_field%>) AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') > 10
THEN 'more than 10 changes'
Bucket with CALC_REWORK:
CASE
WHEN CALC_REWORK ("GTO_Vacancy_Workflow_csv"."FIELD"= <%=With_field%> AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') =0
THEN 'no changes'
WHEN CALC_REWORK ("GTO_Vacancy_Workflow_csv"."FIELD"= <%=With_field%> AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') = 1
THEN '1 change'
WHEN CALC_REWORK ("GTO_Vacancy_Workflow_csv"."FIELD"= <%=With_field%> AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') > 1
AND CALC_REWORK ("GTO_Vacancy_Workflow_csv"."FIELD"= <%=With_field%> AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') <= 5
WHEN CALC_REWORK("GTO_Vacancy_Workflow_csv"."FIELD"= <%=With_field%> AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') > 5
AND CALC_REWORK("GTO_Vacancy_Workflow_csv"."FIELD"= <%=With_field%> AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') <= 10
WHEN CALC_REWORK("GTO_Vacancy_Workflow_csv"."FIELD"= <%=With_field%> AND "GTO_Vacancy_Workflow_csv"."FROM VALUE" != 'NULL') > 10
Throughput time:
TRIMMED_MEAN(CALC_THROUGHPUT(CASE_START TO CASE_END, REMAP_TIMESTAMPS("GTO_Vacancy_Workflow_csv"."CHANGE DATE", DAYS)), 5, 5)
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Jul 29, 2021 9:11 AM UTC
Hi Mariana,
Could you also provide the formula for 'AVG # of changes'? Since disabling that one changes the calculation.
  • Jul 29, 2021 9:42 AM UTC
Sure,
it's AVG(PU_COUNT ("GTO_Vacancy_Current_State_csv", "GTO_Vacancy_Workflow_csv"."FIELD",
The thing is that if I delete this field from both columns, the throughput time calculation will still differ. And only if I add this column to both tables it will show the same throughput time 😮
joos.buijs
  • Level 10
  • Aug 2, 2021 6:52 AM UTC
Hi Mariana,
My feeling is that the difference between PU_COUNT and the CALC_REWORK approach is the way PU functions filter. They consider every record related to the filtered records from the child table (first argument). Hence, it could be that the PU function considers more records somehow. Enabling the AVG # changes formula, both approached have a PU function with the same filters, hence they share the same result.
It's hard to debug without looking at the data but I would recommend adding case counters to both approaches, and comparing your 'check' column in the bottom table for deviations to understand the problem further. Try to narrow down the data to 1 or several use cases where the difference occurs such that you can explain the difference in value by manual calculation, which would lead you to understand which cases / records are filtered in/out.
It's then up to you to pick one of the two approaches.
Hope this helps!
