The Data Model Load experienced an issue with the Data Pipeline Orchestrator Error
  • May 15, 2023 11:28 AM UTC
  • 218 views
dhruv.shah
Level 1
Hi All,
I am facing an issue while uploading data to Celonis.
My transformations are working fine but it fails at the data model load stage with the following error: "The Data Model Load experienced an issue with the Data Pipeline Orchestrator."
Has anyone faced this issue before or knows of a solution to fix this.
Thanks,
Dhruv
muthappan.alaga
Level 8
Do you have any views instead of tables in your model? Reach out to Celonis through support ticket, so they can find out the route cause of the error in the backend.
dhruv.shah
Level 1
  • Level 1
  • May 15, 2023 11:47 AM UTC
Have only tables in my Data Model, No views. Have already raised a support ticket but need a swifter turnaround for the issue.
  • May 16, 2023 6:12 AM UTC
Maybe will work now. Check in status.celonis.com if your cloud had any troubles. Checkin in history I see this from yesterday:
