Source und Target with PROCESS_ORDER
  • Sep 15, 2020 9:42 AM UTC
  • 5 replies
  • 206 views
Hello everyone,
i need a throughput between two consequitive activities and want to implement it via source and target.
Die idee wre source(activity_table.activity), target(activity_table.activity, process_order(target)=process_order(source)+1))
would it work?
Maria
Hi Maria, in order to calculate the throughput time between consecutive activities using SOURCE and TARGET, you can do the following: Dim1: SOURCE("activities"."activity") Dim2: TARGET("activities"."activity") KPI: HOURS_BETWEEN ( SOURCE("activities"."timestamp"), TARGET("activities"."timestamp") ) You can also find examples in the SOURCE / TARGET documentation. Cheers David
  • Level 0
  • Nov 27, 2021 12:23 PM UTC
Hi Marina,
here is a great resource that explains calculations on activity sequences. Check out this documentation which also provides further scenarios + solutions:
https://confluence.celonis.com/display/PQLdevelopment/Calculations+on+Activity+Sequences
Kevin
gabriel.okaba11
Hello Maria,
Better than SOURCE() and TARGET() is to use ACTIVITY_LAG
ACTIVITY_LAG ( table.column [, offset ] )
You could simply use DAYS_BETWEEN,ACTIVITY.ACTIVITY_EN,ACTIVITY_LAG(ACTIVITY.ACTIVITY_EN,1))
Gabriel
sudharani.perum
Level 1
Hi Gabriel,
I have created 2 variables
1.crd_mad_pushout: case when SOURCE (
    "_CEL_O2C_ACTIVITIES"."ACTIVITY_EN" ,
   REMAP_VALUES (
    [ 'Create Sales Order Item' , 'Create Sales Order Item' ] ,
    [ 'Material Availability Date Pushed Out' , 'Material Availability Date Pushed Out' ] ,
    [ 'Customer Request Date Pushed Out' , 'Customer Request Date Pushed Out' ] ,
    NULL
   )='Customer Request Date Pushed Out' and target("_CEL_O2C_ACTIVITIES"."ACTIVITY_EN" ) = 'Material Availability Date Pushed Out'
then   round(datediff(dd,
SOURCE (
    "_CEL_O2C_ACTIVITIES"."EVENTTIME" ,
   REMAP_VALUES (
    NULL
target("_CEL_O2C_ACTIVITIES"."EVENTTIME")))
when target("_CEL_O2C_ACTIVITIES"."ACTIVITY_EN" ) = 'Material Availability Date Pushed Out'
then 9999
ELSE NULL END
2.ecrd_mad_pushout:
case when SOURCE (
   REMAP_VALUES (
    [ 'eCRD Pushed Out' , 'eCRD Pushed Out' ] ,
    NULL
   )='eCRD Pushed Out' and target("_CEL_O2C_ACTIVITIES"."ACTIVITY_EN" ) = 'Material Availability Date Pushed Out'
SOURCE (
   REMAP_VALUES (
    NULL
then 9999
ELSE NULL END
which calculates the date difference between 2 set of activities
when i am trying to keep filter using these two variables, getting error
“No common table could be found. The tables [<Temporary table: SOURCE/TARGET configuration _CEL_O2C_ACTIVITIES,REMAP_VALUES ( "_CEL_O2C_ACTIVITIES"."ACTIVITY_EN" , [ 'Create Sales Order Item' , 'Create Sales Order Item' ] , [ 'Material Availability Date Pushed Out' , 'Material Availability Date Pushed Out' ] , [ 'Customer Request Date Pushed Out' , 'Customer Request Date Pushed Out' ] , NULL ),ANY_OCCURRENCE [ ] TO ANY_OCCURRENCE [ ]>] and [<Temporary table: SOURCE/TARGET configuration _CEL_O2C_ACTIVITIES,REMAP_VALUES ( "_CEL_O2C_ACTIVITIES"."ACTIVITY_EN" , [ 'Create Sales Order Item' , 'Create Sales Order Item' ] , [ 'Material Availability Date Pushed Out' , 'Material Availability Date Pushed Out' ] , [ 'Customer Request Date Pushed Out' , 'Customer Request Date Pushed Out' ] , [ 'eCRD Pushed Out' , 'eCRD Pushed Out' ] , NULL ),ANY_OCCURRENCE [ ] TO ANY_OCCURRENCE [ ]>] are connected, but have no common table. This means that they do not have a direct (or indirect) 1:N or N:1 relationship. Join path: [Temporary table: SOURCE/TARGET configuration _CEL_O2C_ACTIVITIES,REMAP_VALUES ( "_CEL_O2C_ACTIVITIES"."ACTIVITY_EN" , [ 'Create Sales Order Item' , 'Create Sales Order Item' ] , [ 'Material Availability Date Pushed Out' , 'Material Availability Date Pushed Out' ] , [ 'Customer Request Date Pushed Out' , 'Customer Request Date Pushed Out' ] , NULL ),ANY_OCCURRENCE [ ] TO ANY_OCCURRENCE [ ]]N <-- 1![VBAP]!1 --> N[Temporary table: SOURCE/TARGET configuration _CEL_O2C_ACTIVITIES,REMAP_VALUES ( "_CEL_O2C_ACTIVITIES"."ACTIVITY_EN" , [ 'Create Sales Order Item' , 'Create Sales Order Item' ] , [ 'Material Availability Date Pushed Out' , 'Material Availability Date Pushed Out' ] , [ 'Customer Request Date Pushed Out' , 'Customer Request Date Pushed Out' ] , [ 'eCRD Pushed Out' , 'eCRD Pushed Out' ] , NULL ),ANY_OCCURRENCE [ ] TO ANY_OCCURRENCE [ ]]. For more information on the join path, search for "Join functionality" in PQL documentation”
Can you help me with this
sudharani.perum
Level 1
Can you please help me with the above one ​@gabriel.okaba11
