Setting up a OAuth 2.0 connection to SuccessFactors
  • Jun 10, 2024 9:10 AM UTC
  • 199 views
johann.riede
Level 3
Hi community,
has anyone managed to set up a OAuth 2.0 connection to SAPs Success Factors yet?
We're running in some issues there and I'd be happy to know if there are users out there who were able to successfully connect the two systems.
Best regards!
Johann
  • Jun 12, 2024 2:54 PM UTC
Hi Johann!
yes, we are now in the process of connecting to SuccessFactors.
We have already received the credentials from IT department but we are also facing some issues with the creation of the custom extractor. Specifically, in setting up the oAuth2.0 Authentication.
Issue during test connection:
Connection test failed, please check the Data Connection's configuration and ensure that the system is running: Cannot read private key
I'll be glad to share as soon as we solve it. Meanwhile, if you want to catch up feel free to reach out.
Regards,
Roberto
johann.riede
Level 3
  • Level 3
  • Jun 26, 2024 1:41 PM UTC
Hi Roberto!
We've encountered the exact problem.
ATM, we're using Basic as authentication - it works, but no one is too happy with that.
Maybe this works with you, too as a workaround/first step.
Regards,
Johann
  • Aug 28, 2024 4:44 AM UTC
Hi Johann,
Hope you are doing well and in good health.
Following up to check if you were able to resolve connecting to SuccessFactors using OAuth2?
Would be happy to learn from your experience and enhance my knowledge if you can share please.
Hi both,
we do not support the OAuth2SAML 2.0 Bearer authentication type yet which is required by Successfactors, so you can only use it via Basic Auth at the moment.
The necessary capabilities to support this authentication method are already on our roadmap for Extractor Builder. We are planning to make this available by January.
