SAP extraction fails for abort in SAP system with log "Error: Error during Hash calculation for value 100"
  • Feb 9, 2024 10:06 AM UTC
  • 164 views
Forum|alt.badge.img+11
I'm extracting data from SAP ECC, but when I try to pseudonymize fields from tables I receive an error of aborted operation from SAP system, with log "Error: Error during Hash calculation for value 100"
Someone please know why?
Thank you!
dennis.pflug
Hi Alice,
do you know on which Data Base the SAP ECC System is operating?
I found a similar error message related to a Solaris10 bug in combination with SHA-256.
Are you using the most common SAP extractor (on SAP ECC system and Extractor Server)?
Or try to select a different Hash Algorithm within "Advanced Settings" section and please also check which hashing_algorithm is selected within application-local.yml file:
https://docs.celonis.com/en/advanced-connection-configurations.html#UUID-4e9e8020-fbdb-1613-2529-f997e49c8839
In parallel I would also create a ticket and asked Celonis support. Maybe they had a similar issue before.
BR
Dennis
  • Level 2
  • Mar 7, 2024 11:15 AM UTC
Hi Alice,
BR
Dennis
Thank you very much Dennis! At the end, it seems that we had an old RFC module with a bug in the hashing algorithm. Once updated with the new version it should work!
dennis.pflug
Interesting.
Do you know which RFC Module version you used in case others are getting the same issue in future?
I think this is a common situation that especially updating of RFC modules is not happening that often (never change a running system) as you might need to involve several other teams (e.g SAP Basis) which takes time, money and ressources.
Thanks,
Dennis
  • Level 2
  • Mar 7, 2024 1:18 PM UTC
Yes, of course! We're using the 3.7.2 version!
You're right, it's the very same issue we have
Thanks for your help!
