PU Max Error - “An aggregation is not a function”
  • Mar 16, 2021 11:20 AM UTC
  • 139 views
Hello community,
I am trying to build a table that will have a ranking of company codes. I use Celonis 4.5 on-prem. The company codes are my dimension. This ranking is based on the below KPI logic:
CASE WHEN
MAX(WORKDAYS_BETWEEN(R2R.Tables::BSEG_KDAS.CAL_ID, R2R.Tables::BSEG_KDAS.LAST_DAY_OF_MONTH,
(PU_MAX( DOMAIN_TABLE (
R2R.Tables::BSEG_KDAS.ENTRY_DATE,R2R.Tables::BSEG_KDAS."_CASE_KEY"),R2R.Tables::BSEG_KDAS.ENTRY_DATE)))) = 3
THEN 1
WHEN
R2R.Tables::BSEG_KDAS.ENTRY_DATE,R2R.Tables::BSEG_KDAS."_CASE_KEY"),R2R.Tables::BSEG_KDAS.ENTRY_DATE)))) = 4
THEN 2
ELSE NULL
the above statement works as expected, however i need to include another variable where it also checks for the time stamp.
I have tried the below statement, however am receiving an error message saying An aggregation is not a function.
Can you please suggest a solution that incorporates both the max day function and the time stamp?
CASE WHEN
(R2R.Tables::BSEG_KDAS.CPUTM > 120000 AND
R2R.Tables::BSEG_KDAS.ENTRY_DATE,R2R.Tables::BSEG_KDAS."_CASE_KEY"),R2R.Tables::BSEG_KDAS.ENTRY_DATE)))) = 3)
THEN 1
WHEN (R2R.Tables::BSEG_KDAS.CPUTM < 120000 AND
THEN 2
ELSE NULL
Thanks,
Anna
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Mar 19, 2021 3:47 PM UTC
Hi Anna,
For me its hard to fully dissect your code quickly. My gut feeling says that your MAX function right after the AND wont work as expected.
In general its a good idea to start small and build it up. So could you create a (temporary) KPI where you try your timestamp logic from small (like a first step you need), then building it up to your intended end result. This usually helps making the steps small and the exact problem clear.
Good luck!
Hi Anna,
as @joosbuijs already said: The issue is near the MAX call in your CASE WHEN condition. The first query works just fine because the CASE WHEN is simply built upon the MAX. However, in the second query, you add a dimensional column without an aggregation around it, and you cannot do that. So you cannot mix aggregates and non-aggregates inside the same statement. In SQL, this would also fail.
You can fix it by also adding an aggregation function (MIN, MAX, SUM, ) around the R2R.Tables::BSEG_KDAS.CPUTM column you have added to your condition, such that everything is again purely based on aggregations.
Another possibility would be to move the condition youve added inside the MAX calls, if possible.
David
