Preview not available "data model load" -
  • Feb 26, 2025 6:47 PM UTC
  • 205 views
Hafsa
Level 3
I'm working on connecting serviceNow to Celonis,
I did Task Extraction (OK) → Task Transformation (OK) and when I loaded data it works (loaded rows OK), but when I press "set as activity table" it gives me the message :  "Preview not available". A table preview is currently not available. The cause may be due to a missing data pool or connectivity issues” without columns to select “Case ID”, “brief description”, “date”.
I need to know why the columns are not showing up in views (after transformation task) but showing up in the original tables….
for information: I tested the data in task extraction, task transformation and loaded data model and they contain all data of the views. I also execute data job for all, but the columns still don't appear.
Thank you in advance for your help,
abhishek.chatu14
Try recreating the data model, did you by any chance rename the activity table once the data model was already loaded ?
Hafsa
Level 3
  • Level 3
  • Feb 27, 2025 8:12 AM UTC
Hello ​@abhishek.chatu14 ,
I can't create a new data model because the columns don't appear :
Same thing with an already created data model, I don't see the clomuns when i press  "Set as activity table" :
For information , In the two tables data is loaded :
Thank you in advance ,
abhishek.chatu14
Raise a ticket with Celonis this seems like some bug
