PQL formula to filter activity sequences by first occurrence
  • Jun 23, 2023 10:55 AM UTC
  • 109 views
Hi there,
i've been doing some tasks for uni and stumbled across a task where i need to return 'AB' if activity A happened before B and 'BA' if B happened before A. We can assume that always exactly one of the cases is true, so no null solutions.
I tried the following PQL formula but it doesnt seem to work:
CASE WHEN(PU_Last("case-table", "activity-table"."ACTIVITY", "activity-table"."ACTIVITY" = 'A') < PU_Last("case-table", "activity-table"."ACTIVITY", "activity-table"."ACTIVITY" = 'B'))
THEN 'AB'
ELSE 'BA'
For some reason the first case never happens. Anyone having any ideas?
Thanks for your help and kind regards
Aaron
  • Jun 23, 2023 11:26 AM UTC
Hi Aaron,
try this Formula IF A MUST BE DIRECTLY FOLLOWED by B:
  • CASE WHEN MATCH_PROCESS ( "Activities"."ACTIVITY" , NODE [ 'A' ] as src , NODE [ 'B' ] as trg CONNECTED BY DIRECT [ src , trg ] ) = 1 THEN 'AB' ELSE 'BA' END
If an activity A has not only to be directly followed by B but can come any time later the keyword CONNECTED BY EVENTUALLY [ src , trg ] can be used.
For more details visit this link : MATCH_PROCESS (celonis.com)
  • Jun 23, 2023 11:31 AM UTC
Hi Rashid,
thank you very much for that fast response.
The formula works like a charm!
  • Jun 23, 2023 11:44 AM UTC
Hi Rashid,
Hi Aaron,
I'm so glad it was helpful :)
