Need help with calculating times between consecutive activities
  • Oct 14, 2023 1:44 AM UTC
  • 6 replies
  • 191 views
Hi! can anyone please help me figure out the following PQL?
I have cases that have a lot of the same activity.
Imagine the activity is "Walk The Dog" and there are activities with the following dates:
  • 1/1/2023
  • 1/8/2023
  • 1/15/2023
  • 1/25/2023
I would like a query that returns the largest number of days between consecutive events
So in this example:
  • 1/1/2023->1/8/2023 = 7 days
  • 1/8/2023->1/15/2023 = 7 days
  • 1/15/2023-1/25/2023 = 10 days
I would like the query to return '10'
I am having trouble with trying to connect the dots with the documentation on calc throughput. Not sure how to approach it.
Best answer by Anonymous
Hi Zsolt! Thank you so much for your help on this! it is almost exactly what I need.
In the example you rewrote above:
001:Walk the Dog (not computed, no previous activity)
002:Walk the Dog (diff gets computed)
003:Walk the Dog (diff gets computed)
004: Walk the Cat (not computed)
005:Walk the Dog (not computed)
I would like the 5th event - Walk the Dog to be computed as it relates to the 3rd event.
I tried looking at using the third example from this documentation: https://docs.celonis.com/en/index_activity_order.html
INDEX_ACTIVITY_ORDER ( REMAP_VALUES ( "Table1"."ACTIVITY" , [ 'A' , NULL ] ) )
but was having difficulty.
I think I need to modify this part of the code to look at the last of the same activity, not just the prior activity.
"CEL_Activity_Table"."_ACTIVITY_EN" = ACTIVITY_LAG("CEL_Activity_Table"."_ACTIVITY_EN",1 )
do you have any recommendations?
Again thank you so much for getting me this far!
solved it -
I changed it to use ACTIVITY_LAG to identify the event time of the last "Walk The Dog" and if there is none, use NULL
ACTIVITY_LAG (
CASE
WHEN
"CEL_Activity_Table"."_ACTIVITY_EN" = 'Walk The Dog'
THEN
"CEL_Activity_Table"."_EVENTTIME"
ELSE
NULL
ELSE
NULL
Thank you again Zsolt!!!!
Hi, have you considered using MAX or PU_MAX in your PQL statement? See the following documents for reference. https://docs.celonis.com/en/max.html https://docs.celonis.com/en/pu_max.html
  • Oct 16, 2023 12:02 PM UTC
Dear Matt,
Make an OLAP table and make the Case Key as dimension. Then make a KPI with the following PQL:
MAX(
CASE WHEN
INDEX_ACTIVITY_ORDER ( "CEL_Activity_Table"."_ACTIVITY_EN" ) <> 1 AND
THEN
DAYS_BETWEEN (ACTIVITY_LAG("CEL_Activity_Table"."_EVENTTIME",1 ), "CEL_Activity_Table"."_EVENTTIME")
ELSE NULL END)
This code makes sure that only the consecutive events (with same activity name) are getting passed to the DAYS_BETWEEN function, which then calculates the days between the two dates.
So for example:
If you have any questions, feel free to reach out.
Hope it helps.
Yours,
Zsolt Borbély
  • Oct 16, 2023 12:42 PM UTC
Dear Matt,
MAX(
CASE WHEN
THEN
ELSE NULL END)
So for example:
Hope it helps.
Yours,
Zsolt Borbély
  • Oct 16, 2023 1:43 PM UTC
Dear Matt,
Right, in this case it is much simpler:
Add this as a component filter:
FILTER REMAP_VALUES ( "CEL_Activity_Table"."_ACTIVITY_EN", ['Walk The Dog', 'Walk The Dog'], NULL) IS NOT NULL;
The PQL of the KPI itself:
MAX(
Alternatively, you could use this as well without component filter:
MAX(
CASE WHEN
REMAP_VALUES ( "CEL_Activity_Table"."_ACTIVITY_EN", ['Walk the Dog', 'Walk the Dog'], NULL) IS NOT NULL
THEN
ELSE NULL END)
Does this solve your issue?
Yours,
Zsolt Borbély
  • Oct 16, 2023 3:13 PM UTC
Again - thank you so much for your assistance! I don't want to use filter because I do need other activities in the same component.
The remap IS NOT NULL solution seems to help not calculate the time between steps. But it does not skip over steps appropriately.
Example of what is happening:
walk the cat - 1/1/2023 - NULL
walk the dog - 1/2/2023 - 1
walk the dog - 1/3/2023 - 1
walk the cat - 1/4/2023 - NULL
walk the dog - 1/5/2023 - 1
Desired result:
walk the dog - 1/2/2023 - NULL
walk the dog - 1/5/2023 - 2
  • Answer
  • Oct 16, 2023 4:12 PM UTC
solved it -
ACTIVITY_LAG (
CASE
WHEN
THEN
ELSE
NULL
ELSE
NULL
