Machine Learning Workbench - Convert to DataFrame
I am trying to convert the data present in an OLAP table to a dataframe.
c = get_celonis(**settings)
w = c.workspaces.find(KPI Analysis - CSAT,None)
a = w.analyses.find(CSAT Model,None)
q=a.published.components.ids[7ae951ac-b933-4e62-b8c0-ee21e6a15845].data
Can anyone please help me what can be the command to convert q into a dataframe.
Thanks!!
Hi Mayukha,
You can retrieve the query of the component using
.pql_query
instead of
.data
With
df = a.get_data_frame(q)
you can then send the query to Celonis to get the dataframe.
There is also an example in the documentation:
https://python.celonis.cloud/docs/pycelonis/en/latest/getting-started.html#Working-with-data
David
Hi David, I have tried the same but I am getting an error while creating a data frame. image.png24881350 376 KB
Hi Mayukha,
We can definitely solve this! First idea: could you update the pycelonis package? You can do this by running:
!pip install -U pycelonis
in a cell of your jupyter notebook.
If you then restart your kernel and run your code again it should work!
Does this solve the problem?
Cheers,
Simon
