Jira Connection
  • Jan 31, 2024 4:02 PM UTC
  • 7 replies
  • 355 views
Forum|alt.badge.img+13
we would like to connect our Jira project to Celonis with API.
we couldn't find a standard connector so we've created a New Extractor with Extractor Builder using REST APIs calls.
For autentication we used API token as specified in the documentation.
The connetion tests run succesfully but, when we try to Build the response we have this error message:
"Cannot get samples from source system: Unable to read the response"
TestConnectionBuildResponse
Can anyone help us to solve the problem ?
Thanks for you time.
Giulia
Sverre Klein
Hi @giulia.franc,
The API endpoint (URL) doesn't seem correct. I have done a bit of research and apparently you can use the following endpoints to get all the issues in Jira:
For Jira Server
https://your-jira-domain.com/rest/api/2/search
For Jira Cloud
https://your-jira-domain.com/rest/api/3/search
Pick the one that is applicable for you. Then the endpoint would look something like this:
https://jira.gft.com/rest/api/2/search OR https://jira.gft.com/rest/api/3/search
EDIT: Celonis Documentation for Jira also states the endpoints under "Jira Data Extraction" --> Jira Connection (celonis.com)
Let me know if this resolved the issue! 😎
Sverre Klein
Hi @giulia.franc,
For Jira Server
For Jira Cloud
To add to the above, there is a Jira connector available, but you need to request it apparently. 😅
  • Level 2
  • Feb 1, 2024 9:24 AM UTC
Hi Sverre,
thanks for your reply!
the first link:
"https://jira.gft.com/rest/api/2/search" work (I try it from the browser)
I change the URL in the configuration but I get the same error. 😔
TestConnection_2BuildResponse_2
I'll also try to request for the connector...
Thanks
Giulia
Sverre Klein
Hi Sverre,
the first link:
Thanks
Giulia
Hi @giulia.franc,
I think the endpoints I gave you are only valid using the connector, which you have to Request by creating a support ticket in Celopeers.
The endpoints could be different when building a custom extractor yourself. I have no experience in this, but let's give it a go. 😃
According to documentation from Atlassian (link), you can use the Endpoint: http://jira.gft.com/rest/api/2/search?jql=
This is essentially the same as if you searched in the issue navigator in Jira and left the advanced search field empty; it returns all the issues.
Hopefully this works!
Sverre Klein
Hi Sverre,
the first link:
Thanks
Giulia
I hope you have solved the issue? @giulia.franc
  • Level 2
  • Feb 6, 2024 9:18 AM UTC
Not yet!
there are problems with the firewall....
we are trying to install an agent locally!
Sverre Klein
Hi @giulia.franc,
Checking in again 😊. Was the agent installation successful?
Sverre Klein
