I have fully loaded data model in data integration but i do not see and rows when i use the Data model in Studio?
  • Sep 11, 2023 8:44 AM UTC
  • 134 views
I have created a new space in studio to analyse master data changes in SAP, The data integration part is successful and the data model along with activity and case table also seems to load successfully.
Data
But when i use the same data model in studio, it shows that the tables have no rows.
Data
Can anyone please help me. I have been trying to solve this since last week and still cannot figure out. :( What am i missing?
abhishek.chatu14
This may be a check you may have already performed, however what does select count in Vertica SQL i.e. Transformation return for the same. If your data model has loaded have you checked if the table has values basically ?
Another thing you can do is go to the data model details and under Data Load Progress you should see the number of rows that have been loaded for the table.
  • Sep 12, 2023 6:52 AM UTC
Hey Abhishek,
We found the issue it was related to data permission applied on the data model. But thanks for your answer
