How to get KPIs values through PyCelonis?
  • Jul 21, 2025 8:12 PM UTC
  • 170 views
andres.naran12
Level 8
Forum|alt.badge.img+10
Hi everyone, some months ago, I faced a challenge related to getting variables from a view using PyCelonis. Today I have another challenge where I need to get the result from multiple KPIs and send it back to the data pool.
At the beginning, I used the module “Get Rows” from action flows, and I was able to get the values from each KPI. However, in some KPIs, the values that I’m getting inside actions flows, are completely different from the ones that exist in an OLAP’s table where those KPIs are being used. I don’t understand the reason for this, so I was thinking of a workaround solution with PyCelonis, where I would get the values from each KPI and create a dataframe that can be sent to the datapool.
I can see in the documentation that we can get the values from records, but only of those records that exist in a data model. But I cannot see in the documentation how to deal with KPIs.
Does anyone know if is there a way to get the value of multiple KPIs with PyCelonis, pls?
