How to filter analysis by location/plant/department
  • January 24, 2020
  • 5 replies
  • 100 views
Hi, I would like to create an analysis for three of our depts. together.
The department is one of the characteristics of activities and the whole process is not only happens in those 3 depts of interest.
If I use filter ACTIVITY_TABLE.DEPT IN (1,2,3) Celonis cuts all the activities that were performed in other departments. I am rather interested in all the cases that were ever touched by my 3 Departments no matter if some of the activities were performed somewhere else - the process should be shown completely.
Thank you!
attila.cserv11
Level 3
Forum|alt.badge.img+16
Hi @DrWindy,
try using the general selection (the dashed rectangle selection feature in the uppermost line) for selecting all cases containing at least one activity relevant to your 3 departments:
  1. click add new selection
  2. choose attribute selection
  3. choose your activity table in the leftmost table-list (it should be ACTIVITY_TABLE as you wrote) -> its fields drop down
  4. select the DEPT field (column)
  5. in the mid area tick the DEPT values you are interested in (1,2,3)
  6. confirm your selection -> it is added as a general filter for all your analysis tabs
Does it work? Best regards
  • Level 7
  • January 27, 2020
Hello and thank you for your reply:)
I am not inerested in General Secelction - the users have to always be careful that the filter is set AND I have to make sure that they will get ONLY the relevant info due to the data security. So I am interested in a global filter for my whole analysis.
Maria
  • Level 0
  • January 27, 2020
Hi @DrWindy,
the feature you are looking for is called authorization objects in Celonis4, data permissions in the IBC. In Celonis4 the setup works as follows:
  1. Create an object in the authorization menu
  2. Link the object to the corresponding field in the data model
  3. Assign the allowed values in the userprofiles
https://aws1.discourse-cdn.com/business6/uploads/celonis4/original/2X/f/fa14e46756674a812b0ea0e25bb02c87ece50afa.pngPlease note that I described the manual approach, you can also load the mapping from a database table.
Pol
  • Level 7
  • January 27, 2020
Thank you Pol
I am not an administrator and would be happy if there is a solution for the global filter otherwise our authorisation-system will become extremelly complicated. Moreover, I do not want only specific users to see the cases touched by the 3 depts, but als any other user looking exactly in this analysis to see the only cases relevant for these 3 depts.
Maria
  • Level 0
  • January 27, 2020
Ok I see In that case you could try: FILTER PU_COUNT_DISTINCT(CASES,ACTIVITY_TABLE.DEPT, ACTIVITY_TABLE.DEPT IN (1,2,3))=3 Best Pol
