How many prebuilt connectors does Celonis have?
  • Sep 27, 2022 12:35 AM UTC
  • 6 replies
  • 117 views
Hi process miners,
I'm doing some pitchdeck/marketing work and I'm wondering how many prebuilt connectors Celonis has. Based on this page, there is 20 https://docs.celonis.com/en/data-connections.html, but UiPath process mining has over 50. I can't imagine UiPath has more than Celonis,. Does anyone have a total number of prebuilt connectors?
  • Sep 27, 2022 11:10 AM UTC
Hey Cole,
I guess it depends slightly on your definition of prebuilt connectors. Celonis has 20 source systems to which it can connect those are the ones you are referring to I think. In addition, one of these is the JDBC connection, which also allows you to connect to 26 types of databases across different sources (such as Azure SQL, Bigquery, MySQL). Further, you could refer to prebuilt connectors as specific settings configure for certain processes (O2C, P2P, etc.). If you go to the marketplace within your Celonis team, you will find a page with all connectors there (65 in total). Hope this helpsPrebuilt connectors in MarketPlace
  • Sep 27, 2022 2:19 PM UTC
Hey Cole,
Thanks so much for this info, Maurits. I'm thinking UiP has counted their 50 in a similar fashion as Celonis' 65. Going to run with that.
  • Sep 27, 2022 2:24 PM UTC
Hey Cole,
How'd you find the image with the 65 connectors? Can't seem to find that Celonis Marketplace page
imagethis image
  • Sep 27, 2022 2:28 PM UTC
Hey Cole,
https://<your-team>.<your-server>.celonis.cloud/store/ui/search?type=CONNECTORS
This link should do the trick for you when filled in for your specific environment.
I did notice that for my partner environment I'm able to see 62 connectors, while for a customer I'm able to see 65 connectors. So there might be a slight discrepancy in what connectors Celonis has enabled. As a selling point, I would therefore emphasize that Celonis has over 65 pre-built connectors and this number is growing as partners are developing their own connectors for more and more systems.
  • Sep 27, 2022 2:37 PM UTC
Yeah weird, my partner portal has 71 results for connectors. Either way, it's more than UiPath's, so I'm happy. Thanks for your help!Capture
