Hi Team,Is it possible to set up an extractor and use the same extractor and pull data from two different databases.Assume an extractor is setup to fetch data from oracle database. How can we use the same extractor to pull data from sql server?
  • Mar 4, 2022 9:22 AM UTC
  • 66 views
What changes are required in configuration xml?
If we have to start the extractor with login credentials, then how can use the same extractor for another data source?
Since TCP/IP ports are different for two data base systems how can we use same extractor to pull data from two different databases?
Hi Surya, thank you for reaching out! please be informed that it is possible to connect multiple teams/source systems using the same Extractor (https://help.celonis.cloud/help/pages/viewpage.action?pageId=18579639) but we recommend just using multiple Extractors on the same Extractor server (different ports). That is to prevent potential issues when extracting from multiple source systems with one Extractor due to, e.g., different source system drivers. Best regards, Rrezarta
