Help needed with a % connection path KPI
  • Oct 13, 2023 3:05 PM UTC
  • 90 views
I am trying to figure out how i can make a connection KPI which shows the path percentage of cases that passed through. now i want to see the path percentage flow from each individual Activity. exmaple: Start -->Activity A (branches pathways) ---55% for a path---> Activity B (branches Pathways) --23% for a path--> activity Z. so from each Acitivy i want to calculate how much of the (total) cases that landed there go a certain path % wise.
Now i figured out by doing: COUNT (DISTINCT SOURCE ("Table"."colum")) / GLOBAL(COUNT (DISTINCT SOURCE ("Table"."colum"))) I can filter the path connections to % based on the Total amount of cases present in the dataset.
This only shows me how cases % wise flow through the whole process. but not from an indivual activity.
In my mind somehow every Activity point needs to be seen as the "new" total 100% so a calculation can be made for the paths. but i cannot figured that out.
exmaple:
Start (100 cases) Branches to Acitivity A (50 cases) and B(50 cases) Both pathways would show 50% on the path connection. Lets go further on A: A 50 cases splits to activity D (30 cases) and K (20 cases). Now the pathway to D should show 60% (=30/50) and K 40% (=20/50). etc. etc. etc.
  • Oct 17, 2023 11:38 AM UTC
I Somewhat found a way to achieve the % distribution per activity. but its not perfect yet.
So for the KPI connection path i made the following formula:
The bold letters show the {Table] and the cursive bold the [Table column]
Case when count (SOURCE("_CEL_CSV_ACTIVITIES"."ACTIVITY_EN")) >0.0
Then count (SOURCE("_CEL_CSV_ACTIVITIES"."ACTIVITY_EN")) / global (COUNT_TABLE("Case Table"))
Else NULL END
The formula works best when zoomed in to one particulair proces circle. for instance if you can order online and in the shop some activities wont be used by one or another. this would interfere in the calculation for some unkown reason.
Sometimes the pathways when added up show more then 100%. This is an indicator that some unique case(s) go through the activity multiple times. (although this is a by product from its orginal intention and not the best to find out rework.)
