Filter using agregation
  • Jan 15, 2020 8:36 PM UTC
  • 118 views
Dear team,
We have an indicator related vendors who has been paid with both, MM and FI invoices and we calculate this as a ratio, so far so good.
The problem is when we want to provide the list of those vendors for further review, We have the dimension Vendor and one calculated column that states whether the vendor has FI and MM invoices or either FI or MM which we understand is not subject to review and its listed as OK
as the vendor has both FI and MM is calculated as an aggregation. (See formula below) I can not implement a filter just to show only those that are FI + MM , in the screenshot below i would like to exclude those that are OK
Do you have any suggestion?
All the best ,
image1418575 31 KB
CASE
WHEN
SUM( CASE WHEN BKPF.AWTYP != RMRP AND BSEG.BSCHL = 31 THEN 1.0 ELSE 0.0 END ) > 0 AND
SUM( CASE WHEN BKPF.AWTYP = RMRP AND BSEG.BSCHL = 31 THEN 1.0 ELSE 0.0 END ) > 0
THEN FI + MM
ELSE OK
Hi Christian,
as far as I get your issue correctly, you want to apply a filter that filters out all cases that are OK. In this case you can simply apply a component filter as follows:
FILTER
CASE
WHEN
THEN FI + MM
ELSE OK
= FI + MM
(I assume that the CASE WHEN statement works fine in your analysis. Otherwise please let me know)
I hope that itll solve your issue!
Justin
Hi Justin,
Thanks a lot for your reply, The solution proposed does not work, i tried that on the past, I believe the reason is that Im using aggregation to calculate the categories.
image1146246 6.9 KB
Hi Cristian,
instead of a regular SUM, you need to use PU_SUM.
In the first argument of the PU function you need to specify the grouping. Im not familiar with your data model; its either the vendor table or a DOMAIN_TABLE with the dimensions you have in your OLAP table. The second argument of the PU_SUM is the part that you already have in your SUM.
So the filter would look sth like this. If this doesnt work or it returns a wrong result, please show the queries of the dimensions of your olap table.
FILTER CASE WHEN PU_SUM( "Vendors", CASE WHEN BKPF.AWTYP != RMRP AND BSEG.BSCHL = 31 THEN 1.0 ELSE 0.0 END ) > 0 AND PU_SUM( "Vendors", CASE WHEN BKPF.AWTYP = RMRP AND BSEG.BSCHL = 31 THEN 1.0 ELSE 0.0 END ) > 0 THEN FI + MM ELSE OK END = FI + MM
David
Dear David,
Thanks a lot for your help, I changed my formulas and the filters using pullout functions and now its working as desired. I need to start thinking more on using aggregations !
All the best
