Filter for two entries from the same column / 'AND' instead of 'OR'
  • Jun 26, 2023 10:38 AM UTC
  • 9 replies
  • 105 views
niclas.schmi11
Level 2
Forum|alt.badge.img+11
I wanted to use the following filter statement which unfortunately doesn't work:
FILTER "Table"."type" = (<%=type1%>) AND "Table"."type" = (<%=type2%>);
Strangely enough, the filter does work if I replace the 'AND' with 'OR' like the following:
FILTER "Table"."type" = (<%=type1%>) OR "Table"."type" = (<%=type2%>);.
However, this would have the same result as an 'IN' statement like the following:
FILTER "Table"."type" IN (<%=type1%>, <%=type2%>);
But I need an 'AND' or an 'IN' where all selected 'types' are true and not only one from the 'IN' list.
Can someone please help me with that issue?
  • Jun 26, 2023 12:12 PM UTC
Hi Niclas,
try this code:
FILTER "Table"."type" = (<%=type1%>);
FILTER "Table"."type" = (<%=type2%>);
I hope it will solves your problem
niclas.schmi11
Level 2
Hi Niclas,
try this code:
Hi Rashid,
thanks for you feedback.
Unfortunately, your solution also doesn't work. Individually both filter statements work, but both combined unfortunately not.
  • Jun 26, 2023 12:36 PM UTC
Hi Rashid,
Hi Niclas,
That's strange.
Maybe try a dropdown with multiselection of the column "Table"."type" ? This will work like a Filter selection
  • Jun 26, 2023 12:47 PM UTC
Hi Rashid,
Hi Niclas,
I found this function too:
Filter BIND_FILTERS( "Table", "Table"."type" = <%=type1%>, "Table"."type" = <%=type2%>);
niclas.schmi11
Level 2
Hi Rashid,
Hi Rashid,
multiselection of the column again works like an "IN"-Statement, so not both types have to be in the case, but only at least one.
The BIND_FILTERS i tried as well...unfortunately, with the same outcome. It works with only one limitation (e.g. "Table"."type" = <%=type1%>), but not with both.
dany.moual11
Level 5
Forum|alt.badge.img+7
Hi Rashid,
the AND condition is muttually exclusive and therefore, cannot happen simultaneously. The OR condition in opposite is the unio of both sets.
In Other word, when you write "Table"."type" = <%=type1%> and "Table"."type" = <%=type2%>, you are selecting values that are at the same time <%=type1%> and <%=type2%>, and this is inpossible.
I would suggest you use IN_LIKE ( <%=type1%>, <%=type2%>) or just IN ( <%=type1%>, <%=type2%>)
Good luck,
Dany
niclas.schmi11
Level 2
Hi Dany,
as explained neither "IN" nor "IN_LIKE" will result in the outcome that I need. What I would need is something like "In_both" which is obviously not available.
Is there no work-around for such an use-case in PQL/Celonis? I even tried to use the types as "ACTIVITY_DETAILS" and then work with the activity table.
However, if I then try to filter for cases which have the activity twice and try to count the distinct "ACTIVITY_DETAILS", after filtering for two types, I get skewed results with cases that actually got the activity twice, but only one of the two filtered "ACTIVITY_DETAILS".
matt.witty13
I think what you're trying to do won't work. The logic wouldn't allow it.
Let's say you have a list of values like this: [0, 1, 2, 3, 4, 5]
And you ask Celonis to pull out values that equal both 1 and 2. The way the logic will process as written will look to see if a value is both a 1 and a 2 at the same time, which it can't logically be both a 1 and a 2.
If you said look at one column and pull a specific value and then look at a different column and pull a different one, that would work.
Can you explain your use case a little more to see if a solution could be found?
Yes, an AND doesn’t make sense for one column. One column of one row can only has one value.
