Extract Data Model Load Status logs from Celonis
  • Nov 7, 2019 2:37 PM UTC
  • 152 views
Hi Team, Is there any way we can extract the data model load status logs from Celonis. Could see some configurations to extract ACCESS_LOGGING and LOGIN_LOGGING from Celonis logs. Looking for similar configuration set up steps to pull the data model load status logs from Celonis Application. Any help on this is highly appreciated. Thanks, Aashik
Hi Aashik, Welcome to the Celonis Community Its possible to track your data load data in Celonis and to display it in an analysis. Attached youll find a guide on how to set it up. Cheatsheet - Data Monitoring.pdf (2.0 MB) Best wishes, Calandra
  • Level 0
  • Nov 27, 2021 11:43 AM UTC
HI All,
within the EMS you are now able to monitor the entire Datapipline with a prebuilt connector. Check out this documentation for it:
https://[team].[clutster].celonis.cloud/help/display/CIBC/Custom+Data+Pipeline+Monitoring
Kevin
