Does Celonis EMS has the function to consoliate several applications, with differnt data model, into 1 cockpit view? And also use common feild, such as "Material number", for all those application to dynamicly filter those app in that 1 view?
  • May 10, 2024 6:51 AM UTC
  • 127 views
li.yan
Level 1
santosh.korad
Level 4
Hi Yan,
Yes EMS has a composite approach where in you have to initially define the Material Number in all the data models where you want to use it in the View's by using a set identifier or assigning a primary key and later in the front end view you can assign a filter to the Material Number in all the view's which are plotted in common data models.
li.yan
Level 1
  • Level 1
  • May 10, 2024 8:58 AM UTC
Hi Yan,
Thanks for the quick answer.
Then, if I want to learn more how to plot those several app into 1 view, and how to initially define the Material Numbe in all th data models, how can I proceed next?
santosh.korad
Level 4
Yan,
Check out this link which can help you on this topic.
Connect Custom Processes | Celonis Academy
