Deviding KPI1 / KPI2 does not work. Why?
  • Jun 9, 2020 9:08 AM UTC
  • 5 replies
  • 124 views
steven.bernd
Level 6
Hello everybody,
I have a problem, which is definitely easy to solve, but I lack the idea.
I have a KPI 1:
COUNT (DISTINCT CASE WHEN EBAN. LOEKZ = X THEN EBAN. BANFN ELSE NULL END)
I have a KPI 2:
COUNT (DISTINCT CASE WHEN MATCH_ACTIVITIES (NODE [Technical Clarification]) = 1 THEN EBAN. BANFN ELSE NULL END)
I would like to divide KPI 2 / KPI 1 in a new KPI 3.
The new formula
unfortunately does not work that way.
Can anyone help why?
Thanks a lot
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Jun 9, 2020 2:22 PM UTC
What does not work? Do you get an exception? Or an unexpected result? Or??? I would need a bit more information to help you out.
steven.bernd
Level 6
  • Level 6
  • Jun 9, 2020 2:48 PM UTC
Sry, we speak from an wrong result, not an error. image1452881 76.5 KB #technical-implementation I hope this picture helps.
joos.buijs
  • Level 10
  • Jun 10, 2020 6:55 AM UTC
Hi Steven,
First of all I would set the formatting not to .10% but to decimal.
Second, I believe 10268 / 78 = 131.64
image612627 79.2 KB
Please let me know if this fixes stuff.
steven.bernd
Level 6
  • Level 6
  • Jun 10, 2020 8:42 AM UTC
Im sorry.
yesterday was not my day.
I mean of course KPI 2 : KP1, so 78 : 10.268
But the formula order is correct.
With the .10% I just wanted to make it clear that my result is 0.
0 as a result is wrong.
joos.buijs
  • Level 10
  • Jun 10, 2020 8:55 AM UTC
Sorry for beeing persistent but could you change the formatting to decimal? I find that incorrect formatting strings might mess up the output. Once we get the PQL working, you can tweak the formatting all you like
