Delta Extraction
  • Feb 4, 2025 5:04 AM UTC
  • 278 views
rishabh.agrawal
Level 1
Hey all looking for some insights whether this will work or not if I want a previous years data e.g ( I have 2023-2025 data in CDHDR but I also want 2022 ) can I change the UDATE filter from ( 2023 to NOW ) to ( 2022 to NOW) and disable the change date check  and do a DELTA load to only extract fresh records that are not present in celonis ( even if it’s from the previous year of already ingested data )
kailash.potha12
Hi ​@rishabh.agrawal - Yes, this method is effective, and I frequently use it for large tables. Please ensure that you perform a delta load.
