Datapipeline issue between Celonis Studio and Machine LEarnign Workbench
  • Jul 6, 2026 10:11 AM UTC
  • 920 views
Sagar_MTB
Level 5
Hi Guys,
I am currently facing issues with the datapipeline between celonis studio and the machine learning workbench. The ML Workbench is unable to access Celonis data due to outdated celonis_ml dependencies that rely on deprecated sklearn functions. This breaks the built-in data pipeline and prevents direct data model access. As a workaround, data had to be exported manually as CSV and processed externally. An update to the ML environment and data connectors is required to restore full functionality.
Is there a fix or a workaround for this?
  • Celonaut
  • Jul 6, 2026 1:17 PM UTC
This is a  issue that usually stems from a conflict between legacy packages (celonis_ml or older pycelonis 1.x versions) and updated Python/scikit-learn ecosystems. Because older Machine Learning Workbench (MLWB) environments cannot be upgraded in-place, the underlying dependencies eventually break.
Short-term workarounds and the recommended long-term fix:
If you need to patch your current notebook immediately, try the following in your MLWB terminal:
  • Fix the sklearn dependency naming block: Older installers explicitly look for the deprecated sklearn package name instead of scikit-learn. Try explicitly installing scikit-learn first, then installing your package:
    Bash
    pip install scikit-learn
  • Target a stable legacy version: If you are hitting InvalidVersion or signature errors, completely clean out and target a stable 1.x release of PyCelonis:
    Bash
    pip uninstall pycelonis -y
    pip install pycelonis==1.7.6 # or 1.7.7+ depending on your specific error
2. The Recommended Long-Term Fix (Environment Refresh)
Since Celonis does not support in-place upgrades for older MLWB underlying instances, the cleanest path forward is to migrate to a fresh environment and modern syntax:
  1. Backup your work: Commit your current notebooks/code to Git or export them as a ZIP file.
  2. Provision a new MLWB: Create a brand-new Workbench instance from the Celonis Studio overview page. Newly provisioned workbenches automatically inherit the latest Python environment and updated core dependencies.
  3. Migrate to Modern PyCelonis: Move away from the legacy celonis_ml wrapper and use the native pycelonis API to pull data models directly. For example:
gagan1
  • Community MVP
  • Jul 6, 2026 2:26 PM UTC
Hey ​@Sagar_MTB ,
Current version is 2.x (the 1.x line is deprecated). If you hit dependency issues during the upgrade, the cleanest path is actually to provision a fresh MLWB environment from Celonis Studio — newly provisioned workbenches come with the latest pycelonis and all dependencies pre-installed and pre-configured.
Docs for reference:
https://celonis.github.io/pycelonis/latest/
https://docs.celonis.com/en/getting-started-with-the-ml-workbench.html
Sagar_MTB
Level 5
  • Level 5
  • Aug 10, 2026 2:32 PM UTC
Hi, Thank you. I finally resolved the ML Workbench issue by creating a new Workbench instance, and now the connection is successful. Appreciate your help!
However, I'm facing a new problem. PyCelonis connects successfully using get_celonis(), and I can access objects like celonis.data_integration, celonis.studio, and celonis.apps. But when I run celonis.data_integration.get_data_pools(), it returns "Number of pools: 0". Similarly, celonis.studio.get_spaces() does not return any spaces. The logs also show permissions as empty lists (e.g., ml-workbench permissions: [], team permissions: []). My goal is to access a Data Model/Knowledge Model containing a table from ML Workbench. Has anyone experienced a situation where ML Workbench authenticates successfully but cannot see any Data Pools or Studio Spaces? Does this indicate a permissions issue or does the Workbench need to be explicitly connected to a Data Pool/Space? Any guidance would be greatly appreciated. Thanks!
abhishek.chatu14
check the following
