Data Permissions - Ideas for 0-to-Many relationships
  • Aug 26, 2020 3:22 PM UTC
  • 83 views
maximilian.hoffm13
Level 4
Dear Community, Im currently working on setting up data permissions on IBC. They work as excpected, but that is somehow a"problem" as well. Heres an example of my data model: grafik835223 5.33 KB The two tables are linked via two columns, a company code and an event id. Additionally, the two tables have a 0-to-many connection, meaning that there can be cases without a connection to the events table, and vice versa. I want to set up data permissions based on the company code. As far as I understand (and validated during testing), data permissions are always AND connected, and the tables are always inner-joined This means, when I set up data permission on column cases.company code, I will not be able to see the events x,y,z, because theres no respective case for them. Vice versa, setting up data permissions on events.company code, the will not be able to see case id 4, because theres no link either. Setting up data permissions on both tables will not lead to any other result due to the AND connection. Again, the permissions work fine and as expected. But i wonder if theres a way to deal with this use case, other than rebuilding the data model or adding dummy records in either table. Do you have any recommendations on how to proceed? I can imagine this problem will arise more frequently when e.g. using multi-event-logs where 0-to-many relationships should occur quite regularly. Thank you for your help! Best Max
Hi Max, Thanks for your very detailed question, that makes it very easy to follow your thoughts! The data permissions work exactly as youve figured out, and unfortunately that makes your original request unable to work. However, the workarounds you described, are also feasible I would suggest to add a table to your data model (if it does not already exist) that contains all used company codes and possibly more information to specify them. Then you can join this table to your case table and also use it for data permissions. Best regards!
