Data model load - Best Practice for Foreign Key Join Error Due to Duplicates?
  • Jul 13, 2026 7:11 AM UTC
  • 521 views
el.mostafa.janah
Level 2
Hi Community,
I'm getting the following error while loading my data model:
Could not execute foreign key join: there are duplicates on both sides of the specified key relationship.
Table EKKO, key columns (MANDT, LIFNR), key ('011', '0000805024').
What is the recommended best practice for resolving this issue?
  • Should the duplicate records be removed, or should the join relationship be adjusted?
  • If removing duplicates is the preferred approach, how do you typically handle it? I have already identified the duplicate records, so the only remaining step would be how to delete them.
Thanks in advance for your insights and recommendations!
Hi ​@el.mostafa.janah,
In your example, I think you want to join EKKO (PO Header) to LFA1 (Vendors)?
In this case, the (MANDT, LIFNR) combination should be unique in the Vendor table and the second scenario to remove the duplicates is preferred.
How to remove this depends on your situation:
Forum|alt.badge.img+28
