Data Load issue in _CEL_P2P_ACTIVITIES for file uploads
  • Apr 8, 2020 5:37 PM UTC
  • 167 views
Im trying to load some files, the model is correctly loaded with correct foreign key, have loaded both files with the same datatype INTEGER for _CASE_KEY column. While trying to load data, im facing the issue mentioned below: Data model load failed during load to engine: Could not load data model. Load failed. Error Message: Error while joining table PO_DISTRIBUTIONS_ALL_xlsx_Export_Data with table _CEL_P2P_ACTIVITIES_xlsx_Export_Data. Data type of column _CASE_KEY doesnt match data type of column _CASE_KEY. Celonis Support ID: 8e12a1b3-589b-4720-be56-8b90a0fd6e7d Please help.
  • Apr 9, 2020 1:28 PM UTC
Please ignore, issue got solved.
vassilios.falir
Level 1
How was it solved please?
vassilios.falir
Level 1
ok, this happens when theres a space in the table name
