Cross tables filtering doesn't work in N to 1 to N data model
  • Aug 9, 2025 12:55 PM UTC
  • 6 replies
  • 426 views
Leslie Lei
Level 3
Hello Celonis users,
Good day. There is no chance for me to change anything in the data model and I mainly work in PQL Editor. My goal is to use fields from N-side tables to filter data and visualize it.
More details:
Data model: Table A [N] → [1] Table B [1] ← [N] Table C
Table A:
Material code            Warehouse            Procurement type
1                                  Australia                    External
1                                     USA                        Own produced
2                                      UK                          Own produced
2                                      USA                         Others
3                                   Austrialia                   External
3                                       UK                          Own produced
Table B
Material code              Responsible
1                                        Martin
2                                         Mary
3                                         Julia
Table C
Material code             Distribution  center                Transportation
1                                     Austrilia                                           See
1                                      USA                                              Railway
2                                      UK                                                  Airline
2                                      USA                                               Airline
3                                      Austrilia                                       Railway
3                                      UK                                                    See
I would like to find out materials that are not own produced and not transported through airline and railways. Therefore I created a filter using the code below:
FILTER BIND_FILTERS (“Table B”,
“Table A”. “Procurement type” != ‘Own produced’,
“Table B”.”Transportation” NOT IN (‘Airline’, ‘Railway’)
Though Celonis doesn’t show any syntax errors after executing this code, this filter cannot filter out unnecessary data at all.
Is there any way to fix this issue? Besides, I would be very appreciative if you can share your idea of visualizing “Material code”, “Procurement type” and “Transportation” in the same table.
Many thanks in advance!
joaocarlos.macie
Level 6
Forum|alt.badge.img+3
Hi ​@Leslie Lei ,
I would try this filter:
FILTER (CASE WHEN BIND_FILTERS(“Table B”,“Table A”. “Procurement type” != ‘Own produced’,“Table C”.”Transportation” NOT IN (‘Airline’, ‘Railway’))
THEN “Table B”.”Material code”
ELSE NULL ) IS NOT NULL;
or maybe a drop down filter component with the following dimension:
CASE WHEN BIND_FILTERS ( “Table B”,“Table A”. “Procurement type” != ‘Own produced’,“Table C”.”Transportation” NOT IN (‘Airline’, ‘Railway’)) THEN 'Materials I wanna show' ELSE 'Other materials' END
I hope that helps!
Joao
joaocarlos.macie
Level 6
Hi ​@Leslie Lei
Regarding your last comment
You might wanna try DOMAIN_TABLE() combined with BIND() functions.
I would try something like this:
PU_FIRST(DOMAIN_TABLE( "Table B"."Material code"),  "Table B"."Material code", BIND("Table B",
“Table A”. “Procurement type”), BIND("Table B", “Table C”.”Transportation”)
DOMAIN_TABLE() requires you to use a PU function, so in this example I used PU_FIRST.
Maybe you can try to use the two BIND() functions within the domain table to create a row for each combination of the material code and procurement type and transportation - I haven’t tested it like that though.
Hope that helps!
Joao
Leslie Lei
Level 3
  • Level 3
  • Aug 12, 2025 9:41 PM UTC
Hi ​@Leslie Lei ,
I hope that helps!
Joao
Hi ​@joaocarlos.macie
I appreciate your time a lot! I tried the filter below but unfortunatly it has syntax errors:
The good news is that the second code written by you works well, though I used it to create a column in a table, not a filter dropdown:
However I haven’t though of a way of populating both fields “Procurement type” and “Transportation”  from Table A and C in this new table. More specifically, I can only populate either “Procurement type” or “Transportation”. It seems that PU plus BIIND functions only work in 1 to n to 1 data models, if I’m not mistaken.
Anyhow thank you so much for your help! If you have any new ideas, pls let me know.
Br,
Leslie Lei
joaocarlos.macie
Level 6
Hi ​@Leslie Lei
Glad to know that the code worked in the table!
For the filter, I just realized that the CASE WHEN is missing an “END” in the code I sent you. So that should fix the issue if you need to use it as a filter.
For the second topic, you just helped me remember why I’ve never implemented such scenario! haha I don’t think I ever managed to represent that in a single table in the format you would like to.
However, one thing that came to my mind is that you could use the PU_STRING_AGG() to represent that. It won’t be in the original format you expected, but it might be a nice workaround.
You can create a table with 3 dimensions:
  • Table B.Material Code
  • PU_STRING_AGG ( "Table B" ,"Table A"."Procurement type" , ' - ' )
  • PU_STRING_AGG ( "Table B" ,"Table C"."Transportation" , ' - ' )
Let me know if that helps!
Cheers,
Joao
Leslie Lei
Level 3
  • Level 3
  • Aug 28, 2025 7:48 AM UTC
Hi ​@Leslie Lei
Cheers,
Joao
Hi Joao,
Your solution indeed works. Based on this table, I created some filters to filter for different warehouses. Take UK as an example:
FILTER BIND_FILTERS (Table B, PU_STRING_AGG(Table B, TableA.Warehouse, ‘/’) = ‘UK’, PU_STRING_AGG (TableB, TableC.Distribution Center, ‘/’) = ‘UK’)
Hopefully this will be helpful for your work too!
Leslie
joaocarlos.macie
Level 6
Hi Leslie,
Happy to hear you’ve implemented it and thanks a lot for sharing!
Joao
