Connecting Celonis4.7.2 to GCP BigQuery using Simba JDBC Driver
  • Aug 10, 2022 10:43 AM UTC
  • 95 views
We are trying to connect Celonis4.7.2 (onprem) to the GCP using the BigQuery Simba JDBC Driver supplied by Google.
The .jar files have been unzipped into <installDir>\\lib but trying to connect from the frontend, we encounter the following errormessage:
image.pngHas anyone successfully connected Celonis4.7 (or any other onprem version) to the GCP?
Thank you for your help!
Cheers,
Felix
Dear Felix, Thank you for reaching out to us. In order to be able to assist you further we would suggest sending an email to servicedesk@celonis.com and include information such as: which connection template do you use (e.g. HANA, MSSQL). We would be happy to help. Thank you for your patience and understanding. Best regards, Valmira Abdiu
