celonis data extraction from source system is pull based or push based ?
  • Sep 9, 2022 8:54 AM UTC
  • 106 views
  • Sep 10, 2022 7:50 AM UTC
In general, it is pull-based. In your data jobs within the data integration layer, you can define which specific tables and columns from those tables you want to extract based on the metadata. Running a data job sends a pull request to the connected data source.
There is a data push API available, which can be used in some rare cases depending on your needs.
  • Sep 12, 2022 9:06 AM UTC
Tq so much
