can a Delta load be configured based on string column instead of changing date field
  • Nov 22, 2022 5:32 AM UTC
  • 87 views
sree.c
Level 7
  • Nov 22, 2022 7:00 AM UTC
Yes. We were doing last month several delta loads based on the _CAS_KEY id that was a string. Something like "column" like '20221101%'
In our case, as you see, the initial chars of the case_key codified the date
HTH
