Bold entry variable input
  • December 18, 2019
  • 77 views
Hi All,
Currently I have a dropdown button with manual entries. All of these entries set two variables, of which one concerns the name of the selected entry.
Preferred value to set for the name:
Exclude Invoice Value of Zero: Yes
However, so far I didnt find a way to get this Yes in bold. Regular ctrl + B as well as and (double asterisk) operators dont work. Is there any way to get this done?
Thank you!
Jeroen
Forum|alt.badge.img+27
Hi Jeroen, Does it work if you make it this way? [b] value [/b] You can find this by making a text block and use BB Code Code: Outcome:
Hi, Thanks for your quick reply. As you mentioned, it works in a text block. Unfortunately, it doesnt do so in a variable. Also using the <strong></strong> operator doesnt work. Any other suggestions?
Hi Jeroen, Sorry, I didnt understand totally your question, but now I do. I tried to reproduce your problem, and it looks that the button title only shows plain text instead of text with mark-up like a text box. For now, I dont have a solution for that. Kind regards, Jan-peter
