Abbreviated Number with same number of decimals?
  • Jul 26, 2023 1:48 PM UTC
  • 9 replies
  • 138 views
jonas.schei12
Level 5
Dear all,
I would like to have the same number of decimals for different abbreviated key figures.
With ".3s" I can only define the total number of digits, but I would like to define the number of decimal places for an abbreviated number.
With ".3s" -> 8.07k .... 17.0k but I want: 8.07k ... 17.01k
Thanks in advance!
Jonas
  • Jul 27, 2023 6:03 AM UTC
Hmmm, maybe with some try and error using this info:
https://docs.celonis.com/en/number,-date,-and-time-formatting.html
something like ,.4r2f? No idea if it will work....
Best luck!
jonas.schei12
Level 5
Hi Guillermo,
thanks a lot for your quick reply.
Unfortunately this does not work. Combinations of the number formats generally do not seem to work. Does anyone else have an idea?
Thanks in advance!
  • Jul 27, 2023 8:10 AM UTC
Hi Guillermo,
Thanks in advance!
Well, a "workaround" would be to convert it to string and format it as you please....
kailash.potha12
@Jonas Scheidel - Try this format .3~s
jonas.schei12
Level 5
Thanks @kailash.potha12  I have tried this already but also doesn't work.
marco.marso
Level 6
  • Level 6
  • Jul 28, 2023 11:59 AM UTC
have you already tried it this way ',.2f' ? Granting that you want the comma as thousands seperator..
BR,
Marco
jonas.schei12
Level 5
Hello @marco.marso
thanks for your reply. But with  ',.2f' you lose the format for abbreviation -> target format: 8.07k or 17.01k or 100.25k .... -> same Number of Decimals + Abbreviation (k)
Jonas
marco.marso
Level 6
  • Level 6
  • Jul 28, 2023 12:33 PM UTC
Hello @marco.marso
Jonas
ofc. my bad.
  • Jul 28, 2023 2:40 PM UTC
Is what I do as a workaround, here is the script I use:
CASE
WHEN table.column < 1000000000000 AND table.column >= 1000000000 THEN  table.column/1000000000 || 'b'
  WHEN table.column < 1000000000 AND table.column >= 1000000 THEN  table.column/1000000 || 'm'
  WHEN table.column < 1000000 AND table.column >= 1000 THEN  table.column/1000 || 'k'
  --WHEN table.column < 1000 AND table.column >= 0 THEN  table.column || 'u'
  ELSE table.column
commented out the units as not needed.
