Process Mining Celonis Help
  • Feb 10, 2026 6:04 PM UTC
  • 304 views
deniseagrellos
Level 2
Hi you all
I am student of UFF in Brazil and doing my master degree there wich my tesis is Process Mining using Celonis.
Can anyone help me to use this program.
Iam dealing with some issues and would be very grateful if anyone can help me to continue.
Below my email deniseagrellos@id.uff.br or denise.agrellos@hotmail.com
Many Thanks
Denise
abhishek.chatu14
I would recommend first sharing a bit more detail about the specific issue you are facing. The more precise you can be about the problem (error messages, data model issues, PQL challenges, dashboards, etc.), the easier it will be for others to support you effectively.
You can also post your question in the Celonis Community platform. It is quite active, and someone from the community or the Celonis team will most likely be able to guide you.
For topics related specifically to how the tool works, I strongly suggest going through the Celonis Academy courses. They provide structured learning paths, practical examples, and exercises that are very helpful, especially during a master’s thesis.
If you share more details about your current challenge, I’d be happy to help guide you further.
