Every turnaround is unique, but does that mean we have to start from scratch every time?
  • Nov 27, 2026 10:59 AM UTC
  • 13 views
Jos van der Stelt
Level 2
People who have worked on a turnaround know the saying: "If you've seen one turnaround, you've seen one turnaround." Scope, assets, contractors, weather and what you find once the equipment is opened all change from event to event. Because of that, many organizations treat each turnaround as a one-off project: a new spreadsheet, a new war room, and lessons learned that end up in a slide deck nobody opens again.
I think the scope is unique but the process isn't. Notifications become work orders, work orders need materials, materials need purchase orders, and everything has to be planned, executed and closed out. That repeating pattern is where maintenance and process data can help a turnaround organization. Here's how I'd approach it, step by step.
Start with what happened during your last turnaround
Before planning the next event, rebuild the last one from your system data. How many work orders were in the original scope, and how many were added later? How long did it take to go from notification to approved work order? Where did the work stall? Most organizations have this data but rarely look at it as one end-to-end process.
Treat the scope freeze date as a KPI
Late scope additions drive cost and risk in almost every turnaround. Track how much work enters the work list after the freeze date, and split it into two groups: genuinely new findings, and work that could have been identified earlier. The second group is where you can improve. If the same equipment or the same team keeps adding late work, that pattern shows up in the data.
Check planning and material readiness at fixed points before the start date
Don't ask "are we ready?" once, a few weeks before start-up. Measure it at fixed points, for example T-26, T-12 and T-4 weeks. Link work orders to their purchase orders and delivery dates, and flag every planned job without confirmed materials. Long-lead items should be visible months ahead, not when the scaffolding is already up.
Give the execution phase daily visibility
During execution, conditions change by the hour. Daily insight into work order confirmations, newly found work, backlog burn-down and contractor hours helps supervisors steer instead of react. The goal isn't more reporting. It's spotting the jobs that are drifting while there's still time to act.
Close out properly so the next turnaround starts better
Open work orders, unprocessed confirmations and invoices still waiting for approval months after start-up are common. A structured close-out improves cost accuracy, and it turns this turnaround's data into the baseline for the next one (see step 1). That's how you go from one-off projects to a turnaround organization that keeps improving.
Some ideas I'd like your reaction to:
  • A turnaround readiness index that combines scope stability, material readiness and planning completeness into one view per milestone, so the leadership team can compare readiness across events and sites.
  • Benchmarking across sites or units, not to rank them, but to learn why one site keeps scope growth low while another doesn't.
  • Feeding emergent work back into routine maintenance. If the same findings appear every turnaround, some of that work may belong in the regular maintenance strategy or in inspection plans.
Over to you. I'd like to hear from people who plan, run or support turnarounds:
  1. What was the biggest surprise in your last turnaround, and could the data have warned you earlier?
  2. How do you handle scope additions after the freeze date today?
  3. What would most help you improve your next turnaround: better scope control, material readiness, execution visibility, or something else?
  4. Has anyone set up a structured lessons-learned process that actually carries over to the next event? What made it work?
Share your experiences, tips or disagreements below. I'm especially interested in approaches that work across very different types of turnarounds.
