Oracle Data Base connection from Celonis ML Work Bench
  • Sep 2, 2020 12:36 PM UTC
  • 123 views
Hi Team , I am trying to connect with Oracle Database from Celonis ML using cx_Oracle python Package but getting error as : cx_Oracle.DatabaseError: DPI-1047: Cannot locate a 64-bit Oracle Client library: libclntsh.so: cannot open shared object file: No such file or directory. See https://oracle.github.io/odpi/doc/installation.html for help . Any help or information about this would be highly appreciated . Thank You, Amruth Muddana
Hi @amruth.mudda11,
can you possibly share your code snippet? As assume this issue is related to a wrong access path that is defined. In case you can not share it due to privacy reasons, I would recommend to open a Servicedesk ticket to further work on the issue.
Justin
