Extend SQL Result to more than 100 rows?
  • Jul 16, 2021 11:29 AM UTC
  • 222 views
Hi team,How to extend the result rows for more than 100 or to export the transformation query result to excel?
If not from transformation, is it possible to do it via Machine Learning workspace?
Is it allowed?
Thank you
Forum|alt.badge.img+28
Hi Rahul,
Unfortunately I didn't find a way to do so. Also using Machine Learning, the export of a transformation is limited to 100 rows.
A workaround that we use is creating a table and store it in a dummy data model. Then, using Machine Learning Workbench and PyCelonis, you can retrieve the complete table by using the 'get_data_frame' function. Note that it is not possible to extract directly from the data pool (e.g. the dummy data model step is really neccessary).
An example script to extract data from the data model can be found at the PyCelonis documentation: https://celonis.github.io/pycelonis/notebooks/01_Pulling_data_from_dm.html . Here you can skip the PQL-query part if you want to extract the complete table.
Hope that this helps.
  • Jul 23, 2021 10:58 AM UTC
Hi Jan,
Thanks a lot for your reply.
This helps a lot when we are trying to debug some data and there was no way to access whole dataset.
This will solve it.
Will try this.
Thanks again
Rahul Bhat
Hi Jan,
This will solve it.
Will try this.
Thanks again
Rahul Bhat
Glad that I could help!
